I want to run the interrupt code once on each falling edge on the hint1/pinB.1/leg 22 of a 28X2...
..so set up and enable hint1 on falling edge using hintsetup...
..and set hint1 to call an interrupt routine on hint1 occurring
Input to hint1 is the SQW output of a DS1307 - verified on scope to be a completely clean square wave of period 1.000 seconds....so interrupt should be called once per second
..and the output is...
i.e. waits for first falling edge, interrupt is called and then interrupt is continually called whatever state hint1 is at - steady at low, rising edge etc
Been staring at this for a couple of hours now - must be something completely stupid - help
#picaxe 28x2
#NO_DATA
#NO_TABLE
#TERMINAL 38400
setfreq em32
sertxd("...started", CR, LF)
'interrupt on falling edge of hint1/pinB.1/leg 22
hintsetup %00000010
' enable hint1
setintflags %00000010,%00000010
'print pinB.1 value
sertxd("do loop...pinB.1 = ",#pinB.1, CR, LF)
interrupt:
'print pinb.1 value
sertxd("interrupt...pinB.1 = ",#pinB.1, CR, LF)
'reset interrupts
setintflags %00000010,%00000010 ' enable hint1
...started
do loop...pinb.1 = 0
do loop...pinb.1 = 1
interrupt...pin b.1 = 0
interrupt...pin b.1 = 1
etc
