F1 Quick Syntax popup window behaviour.
tommo_NZ
Hi all. If I remember correctly, in the past didn't the Quick Syntax popup window open with the current hi-lited command displayed, or was that another environment. It is a pain to have to scroll down to find the current command being queried. For some reason, mine always opens at the command "High". I may be quite wrong, as it is some time since I had my Picaxe editor open.
Regards, Tommo,
Running V 6.0.8.11
Having compared PE5 and PE6, both Quick Syntax pop-ups open on HIGH when F1 is pressed, regardless of what has been selected in the source code.
If you click in the list of command names on the left and type the first letter of the command, the selection will jump to / scroll through commands starting with that letter which can save some scrolling
tommo_NZ
Thanks Hippy, I thought it was just me or my installation. I still think I remember it opening on the hi-lited command, which would be nice, but then I seem to remember a lot of stuff that probably never happened.
