Hi all,
For an application I need serial communication at 2400 baud with 8 bits + 2 stop bits or, equivalent, 9 bits + 1 stop bit. The Picaxe can only communicate with 8 bits + 1 stop bit. So I think an external hardware solution has to be made.
Has anyone some experience on using an external (simple) UART with Picaxe? Is it possible to use a Maxim MAX3100 SPI UART or is the Picaxe (16 MHz) to slow for this? Or is there a simple parallel in serial out UART? Or what is possible with shift registers? Any suggestion welcome. (I don't like to use my Motorola micro controllers for this.)
Thanks,
Herman, NL
Thanks,
Herman, NL
