Experimenter's Board
Any tips or hints about using it for the first time?
My recommendation would be to progress through the traditional 'first step' circuits to get a feel for where the connections are and gain confidence in using it.
First step is toggling a LED, then reading a switch to light the LED when pushed, and then it's onwards and upwards, testing each of the hardware items on the board.
One thing to get familiar with is using SERTXD and DEBUG to be able to see what the actual hardware is doing. For example -
#Picaxe 08M2
#Terminal 4800
Symbol LED = C.1
Do
    SerTxd( "LED on", CR, LF )
    High LED
    Pause 2000
    SerTxd( "LED off", CR, LF )
    Low LED
    Pause 2000
Loop
Thank you Hippy
We saw a note saying do not use a 9 volt battery on the battery clip harness.
Always use the 3 1 and 1/2 volt battery holder.
Will this board take a power supply?
Does it have a barrel jack to connect a power supply?
Have a nice day
Bob
@10 am California time
eclectic
Thank you Hippy
Have a nice day
Bob
Page5
There are two options on how to provide power to the Development board, but
ensure only one option is connected at any one time. The green PWR LED indicates
power to the board.
1. Battery - connect a 4.5V (3xAA cell, not supplied) battery box to the screw
terminals, ensuring correct polarity. Do not use 6 or 9V battery packs.
2. Power supply - connect a regulated 9V DC power supply with 2.1mm (positive
tip) connector (not supplied e.g. part PWR009A).
I own two of these boards and from experience, my advice is
1. Buy three PICAXE chips, one for each position. (8/14/20) 18, 28 pin
2. Buy a set of "Dupont" style connectors.
3 Play. :)
e
For my setup I have a bench power supply connected to the screw terminals. That allows the voltage to be adjusted so one can test PICAXE chips and circuits at 3V3 and other non-5V voltages, but most importantly means the supply is current limited. That can be useful for those times where one does make a mistake, short an output or something to 0V and similar.
But perhaps the biggest advantage is there's a switch on the supply which allows the board to be easily powered on and off without having to disconnect the supply. Useful anyway and it makes a power-cycle Hard Reset easier when needed.
Thank you hippy
Sounds there is no on/off switch on this board.
Yes.One of those is a good thing.
25519
We would say these are the sort of connectors are on the board.
In manual we thought they mention 'center positive'. For the 9V power supply.
That sounds like a barrel jack.
We'll find out when board gets here.
Have a nice day
Bob
10:45 AM California time
eclectic
We heard you when you said buy some PICAXE chips.
Here is what is coming with the board:
1pcs,pic axe-20m2 micro controller chip
1pcs, pic axe-18m2 micro controller chip
2pcs, pic axe-28x2 micro controller chips
2pcs, pic axe-40x2 micro controller chips
Another question about your post.
What are 'DuPont' connectors?
Have a nice day
Bob
eclectic
Thank you erco and eclectic
Looks like it has a barrel jack.
Read up on power connections in the little .PDF manual.
Screw connectors run right into board bypassing 7805 regulator.
9V barrel jack runs through the regulator.
This may be the first development board we've gotten with this kind of dual power circuits.
We have a 16F628 board with screw terminals.
Here is the power supply we run it with,
25521
Looking forward to getting this PICAXE board.
Scheduled to get here tomorrow with the mail.
Have a good evening
Bob
@6:15 PM California time
Hi
We have an alert saying OLDMarty responded to this post.
We don't see anything.
Why is that happening?
Happy Holidays!
Bob
@11 AM Saturday California
It could be that OLDMarty posted something then deleted it, perhaps because they felt it didn't add anything to the thread or what they posted was not as relevant as first thought.
Hi Hippy
Sorry it took so long to get back to you.
We will use breadboards at first to test PICAXE.
No way we want to cook this PICAXE board by mistake.
Sure would help if PICAXE would sell the breadboard programming adapter assembled.
Happy Holidays!
Bob
Monday 12/26 @7 pm
