I've searched this topic in the PICAXE forums...while the subject has been discussed before, I didn't find a solution to my problem.
When I run the PICAXE Programming Editor, everything works fine, except every now and then I get the [Error 5: Invalid procedure call or argument error] when attempting to download to the chip. Restarting the editor fixes the problem...for awhile anyway. It does not seem to be code dependent.
I've found that if I'm working on a file, in the editor, then open another (2 or 3 open at once), the error is more likely to appear when I attempt to download to the chip, but that is not always the case. It's very intermittent and has been tough to nail down.
Right now my “fix” is to restart the editor, then continue to work but… that is getting a bit annoying.
Any suggestions?
Thanks for an help you can give,
dersh.
PS...This is on a recently built computer, AMD X2 with Windows XP Pro SP2 (32bit)... it's a clean install with all of the Windows updates. Everything (hardware/software) seems to work on it.
…do you suppose the folks at Microsoft actually use Windows?
Any suggestions?
dersh.
