Paschen's Law provides a relationship between the breakdown voltage, the gas pressure, and the distance between two electrodes. Although Paschen's Law was initially formulated for gas-filled gaps, it can provide an estimation for the minimum gap distance in other insulating materials, such as polymers.
Here is the general formula for Paschen's Law:
V = B × d × p × ln(pd/a)
Where:
- V is the breakdown voltage
- B is a constant that depends on the gas or material being used
- d is the gap distance
- p is the pressure of the gas or material
- a is a constant representing the size of the gas molecules or material atoms
Since you are working with a polymer (DMC), the specific values of the constants B and a would be different compared to gas-filled gaps. Unfortunately, I don't have access to the specific values for DMC. However, you may be able to find these values from manufacturer specifications or by conducting experiments.
Once you have the specific values for B and a for DMC, you can rearrange the equation and solve for the minimum gap distance (d) that will prevent arcing at 10kV. This would involve rearranging the equation as follows:
d = (V) / (B × p × ln(p × d / a))
Keep in mind that this equation assumes a uniform electric field distribution and does not take into account factors such as surface irregularities, moisture, or contamination, which can affect the breakdown voltage. It's always a good idea to consult with a qualified engineer or conduct testing to ensure the design meets safety standards and requirements.
