EEPROM failure vs TABLE use ?
BCJKiwi
Manie,
I think Technical is correct:-
Assuming the code is as per post #36 above, and as explained earlier, table or eeprom are interchanged in the setup part of your program then there is a coding issue.
Table reserves 256 bytes within the program space but eeprom is the same dedicated memory space that is used by the write command.
In the setup locations beginning at 0 thru to 255 are used.
in the case statement ( IdKey: ) writes are made to eeprom at location b0.
At a quick glance, I don't know what the value of b0 is but whatever it is at the the time the write takes place, that eeprom location will be written to which will overwrite the previously stored LCD data in the corresponding eeprom location.
Maybe table is the only option you have.
SilentScreamer
By corrupt he(or she?) means it loses the data that was originally stored in the location that is the same as the value as b20.
An example:
write 15,50
let b20 = 15
write b20,36
You "corrupt" the original value in location 15 with the value 36.
By "corrupt" Technical meant the WRITE may inadvertently change the value of an Eeprom location you are using elsewhere for some other reason so it will not be the value you expected to be there ( as in SilentScreamer's example ). Corrupt as in data damaged under program control, not faulty chip operation.
manie, have you tested your code to make sure that your writes don't overwrite your EEPROM? Ever?
It seems strange that you get repeated 'corruptions' on your EEPROM with several PICAXEs and no-one else does ;)
manie
Agreed ! In Sub "IdKey" this could very well be a case of overwriting. The writes were a remnant and superfluous, removed the writes there, but have not tested again with data in EEPROM. I will test next week-end as I am busy installing the controller in the chicken-house. The above may be true for the 28x1 (LCD driver side). I will have to check with a fine toothed comb in the 40x1 controller side to see if this is also possible.
Believe me ! If that is the case I will be happy (case resolved then) and will beg the pardon of all concerned.
If variable b20 DID overwrite the locations, it just seems a bit funny still that the patterns displayed were almost always identical (triangles in various stances). B20 would have overwritten with 0 through 9 and maybe "#" and "*" which are the values allocated, but certainly what you are saying looks very possible. Wish I had more time to test (installation is 200Km away now, must wait for the weekend...) Thanks for all your inputs......
Values 0-9 may well all appear as the same triangle as they are not correct character values for ascii characters as used by the LCD.
Looks like BB in post #2 may have been correct after all!
Other than that, do you have any WRITE commands in your program?
manie
I would like this resolved as much as everyone, so I will look as soon as I get the chance. I think it was Dippy who said "its a work in progress..." so, lets hope for some positive stuff here......
No, not guilty. :)
The bottom line is that this error happens with your PICAXE+code but with no-one else's. And it happen when you programme another PICAXE with your code.
And it happens on another of your PICAXEs with your code.
3 faulty PICAXEs? I think not.
Your code has some 'writes' in it which we can't see how they affect things.
Ergo.... according to Mr Spock, there is a 99.999% chance it is something you have overlooked. Put on your Deerstalker and get testing all those Write variables ;)
When I saw those 'writes' I wondered why you would want to risk overwriting by having a variable as a <location> parameter?
If you run the program under simulation, crank-up the generic value read by READADC for your key detector, you can clearly see the program overwriting the Eeprom. That may not be a real world test but shows the program is flawed and has the potential for corruption.
Your code is extremely hard to understand or follow. It's not clear what variables are being used for, what they hold or what their values mean. There are also too many cases of 'magic numbers' which are meaningless to anyone other than yourself; "if b18=88 then" etc.
One place where you can massively improve things is with respect to the 'readkey' and 'idkey' routines and the carrying around of some arbitrary word value. Make the two routines into one, use a 'gotKey' or similar byte variable for the result, return zero if no key pressed, an ASCII character of what that key means when pressed. Your ...
temw1=0
do until temw1>0 and temw1<510 'check for "#" pressed
gosub readkey
gosub idkey
pause 20
can then become a much simpler and more understandable ...
Do
Gosub GetKey
Loop Until gotKey = "#"
Programming is a science in getting the right algorithms, interaction and timings but also an art. Aesthetics play an important part and you should aim to make code accessible to others. The pinnacle is writing code which others can follow and understand easily even when its intricacies may be well beyond their understanding. Do it right, and even someone unfamiliar with what the program is doing can find inconsistencies and flaws in reasoning behind the code which is a great aid to debugging and getting help.
manie
The reason I partake in this forum is clearly demonstrated above. Experience has spoken........ I will endeavour to improve on things, thanks, the "Getkey" and "Gotkey" are prime examples of good coding !
Oh well, back to the drawing board !
Don't feel bad about any code because it can always be better and it's rare anyone would do it exactly as anyone else would. I didn't men to be harsh if it came over that way. It takes years of practice to reach 'perfection' and someone will always still complain :)
Life's one long prototype. There's always improvement which can be made. Ripping it up and starting again based on previous experience is the way of the world.
manie
Hippy: NO offence taken friend, just recognition of greater experience and knowledge in a certain subject. Maybe one day I may teach you something on astronomy or so, who knows how the road winds ?
Manie, why don't you put some tests into your code near the 'write' to see if they write to the sections of EEPROM where your 'read only' data was written ? And do a Sertxd to terminal if/when it does.
manie
Dippy: As said before, the writes were a remnant remaining and should NOT have been there at all, so the writes have been removed, I have to download the "corrected" program with the text loaded back into EEPROM and test. I can do that this weekend as the system is already "wall mounted" on site. Then I can let you know.... I'm sure the "write b0, xx" was the cause, but lets check and I'll report back. Hopefully everyone can rest assured then.
Excellent. Fingers crossed.
So when BB said in post #2 "Other than that, do you have any WRITE commands in your program?" then he may have hit the nail on the head? Gosh, two weeks fly by when you're having fun ;)
Well, stranger things have happened at sea....
Then maybe we can rest assured that there is nothing wrong with the PIC.
Not that anyone else was really worried as only poor old Manie was having problems ;)
Microchip can wipe the bead of sweat on their corporate foreheads.
(Just teasing).
Morals:
1. Never post anything more than 10 lines long as people tend not to read it.
2. If 10 people answer before poster gets back then he/she will only read the last one.
3. If there are a bunch of replies and it takes over the page then the poster will often only read the last page.
4. You can even see 'Old Lag' replies echoing things on the previous page...
5. I've got to over 10 lines....
(Just teasing).
We do take ( looking for a not too strong word ) 'suggestions' that the PICAXE is not behaving as it should seriously and investigate the issues. Not least to confirm our, and PICAXE user's, confidence in the product; it can be highly damaging if an unwarranted reputation for unreliability or incorrect operation arises or, worse still, propogates.
"We do take ( looking for a not too strong word ) 'suggestions' that the PICAXE is not behaving as it should seriously and investigate the issues.."
- of course. I would expect you to. Very tactful.
But a condition is "when programmed and used correctly"
Post #8
"BB, there are NO Write's in this program..."
- ah, mate, I'm only teasing. Just like the Lookout said to the Captain of the Titanic :)
Anyway manie, you'll have it tickety-boo soon. Great news. All the best.
SilentScreamer
Personally I see it as an ideal example of how incredibly good your customer service is but others may see it differently.
