I'm writing my first large app (> 1000 lines), and you really notice some weak points in the editor. So, who writes it? Is it likely that they will acknowledge any suggestions? Whats the best way to bring any suggestions to their attention?
Probably because I'm use to working with Microsofts' Visual Studio, a few simple points I miss that I think would really enhance the usability...
1) After doing a search and closing the search dialog, it would be great if you could do a 'Find again' by pressing something like the F3 key.
2) It's a shame that the search dialog box is 'modal' as it prevents you doing anything with the source file behind it without closing it. Particularly annoying if you want to repeat the search without the 'F3' support.
3) It would be nice if the 'Find what' text box on the search dialog was a 'drop down combo box' that remembered the last x number of search words
4) It would be great to be able to comment out large blocks of code with just a start and end marker eg /*......*/
5) It would also be useful to be able to make use of 'include files' whereby some code can be put into a separate bas file and be 'included' in at the point indicated at time of compilation
6) An indication in the status bar of the cursor column number
7) Short cut keys for toggling bookmarks and jumping between bookmarks
Other than that, it's FANTASTIC!
Chris
Chris
