I like to make a suggestion for the Editor that would make the process of correcting mistakes somewhat easier and faster.
Presently the software will stop at any mistake made in the program when the request "Check Syntax" is made. After the correction is made, the user has to repeat the process until all mistakes are found and corrected.
I would like to see the software show ALL mistakes in the program at the same time, so that the programmer can go from one mistake to the next without having to request "Check Syntax" every time, and correct them all in sequence. I think that the time spent on troubleshooting one's program will be greatly improved if the suggested procedure was implemented.
