I want to build around 15 small pcb circuits each with an 08m2 on board which will control an individual servo.
I was thinking that it might make sense to have one power supply for all the picaxe circuits that is regulated and smoothed and another power supply feeding the servo's. The supply for the picaxe's probably won't draw much current but I'm assuming that the one for the servo's will need to be able to supply several amps as there might be more than one servo operating at a time.
I was thinking along the lines of using a couple of transformers to achieve this, but I've never built a power supply circuit before and I'm guessing its probably not as simple as 240v into a transformer and 5v out of the transformer.
I realise that protection in the form of fuses either side is a must but I would be grateful if anyone could advise or share a circuit diagram.
Rgds,
Sid
Rgds,
Sid
