Here is a give-back to the forum.
I have the code for setting and reading a DS3234 RTC chip that come on a break out board from the land of SparkFun.
Here is a basic working version. Enjoy.
#PICAXE 28X2
#terminal 19200
#no_data
#no_table
SYMBOL StdFreq = M16 'Has 4MHz Xtal installed
setfreq StdFreq
SYMBOL abyte = B55 ' W27
SYMBOL aWord = W27
SYMBOL SS = B10
SYMBOL NN = B11
SYMBOL HH = B12
SYMBOL DOW = B13
SYMBOL DD = B14
SYMBOL MM = B15
SYMBOL YY = B16
SYMBOL T = B17
SYMBOL TF = B18
'===-[ DS3234 RTC Pins ]-========================================
symbol CS_RTC= C.2 ' DS3234 RTC chip select
symbol SData = C.5 ' MAX7219 serial data
symbol CS1 = B.2 ' MAX7219 chip select
symbol CS2 = B.6 ' MAX7219 chip select
symbol CS3 = B.7 ' MAX7219 chip select
SYMBOL MOSI = C.5 ' Pin 16 hspi sdO to MOSI
SYMBOL MISO = pinC.4' Pin 15 hspi sdI to MISO
SYMBOL CLK = C.3 ' Pin 14 hspi sck to SCK
'Variable
Symbol _Tmp_1 = b0
Symbol _Tmp_2 = b1
Symbol _Tmp_Data_Snd = b2
Symbol _Tmp_Data_Rcv = b3
Symbol _TMP_bit = b4 ' MISO Bit Value
Symbol _Register_Name = b5 ' Register Name
Symbol _Register_Value_W = W3 ' Register Value as WORD
Symbol _Register_Value_L = b6 ' Register Value LSB
Symbol _Register_Value_M = b7 ' Register Value MSB
'set HIGH CS pin
HIGH CS_RTC
Test1:
_Register_Name=0x81
_Register_Value_L=0x30
'LOW CS_RTC
'SHIFTOUT CLK,SDATA,1,(maxreg,maxdata)
'HIGH CS_RTC
'TRY TO SET the MINUTES to 0 just to see if i can set something
'HIT F5 about 14 seconds before the time you wish to set (on my PC)
SS = 0x30 'Seconds in BCD
NN = 0x48 'MINUTES IN BCD
HH = 0x15 'HOUR IN BCD
DOW= 0x03 'Day of week 1 to 7
DD = 0x07 'Date of month in BCD
MM = 0x06 'Month of year in BCD
YY = 0x11 'YY of the year in BCD
LOW CS_RTC
_Tmp_Data_Snd=0x80
gosub Snd_Rcv
_Tmp_Data_Snd=SS
gosub Snd_Rcv
_Tmp_Data_Snd=NN
gosub Snd_Rcv
_Tmp_Data_Snd=HH
gosub Snd_Rcv
_Tmp_Data_Snd=DOW
gosub Snd_Rcv
_Tmp_Data_Snd=DD
gosub Snd_Rcv
_Tmp_Data_Snd=MM
gosub Snd_Rcv
_Tmp_Data_Snd=YY
gosub Snd_Rcv
HIGH CS_RTC
'Read from Temperure registers
_Register_Name=0x11 'Send start register to read from
_Register_Value_L=0x00
LOW CS_RTC
_Tmp_Data_Snd=_Register_Name
gosub Snd_Rcv
_Tmp_Data_Snd=0
gosub Snd_Rcv:T =_TMP_Data_Rcv 'Read Temp
gosub Snd_Rcv:TF =_TMP_Data_Rcv 'Read fraction of degree
HIGH CS_RTC
' sertxd(" tempMSB reg 0x0E =",#T)
' sertxd(" LSB reg 0x0E =",#TF)
SerTxd(" TEMP = ") 'Display the temperature
aWord=T
GoSub SerTxdWriteWord00
SerTxd(".") 'And the decimal part of the temp 0.25 deg res
TF=TF>>6 'shift from bits 7 and 6 to bits 1 and 0
TF=TF*25 'Scale it
aWord=TF
SerTxd("C",cr,lf)
'READ Time and DATE
_Register_Name=0x00
_Register_Value_L=0
LOW CS_RTC
_Tmp_Data_Snd=_Register_Name 'Send register to start readign from
gosub Snd_Rcv
_Tmp_Data_Snd=0
gosub Snd_Rcv:SS =_TMP_Data_Rcv 'multibyte reads
gosub Snd_Rcv:NN =_TMP_Data_Rcv
gosub Snd_Rcv:HH =_TMP_Data_Rcv
gosub Snd_Rcv:DOW =_TMP_Data_Rcv
gosub Snd_Rcv:DD =_TMP_Data_Rcv
gosub Snd_Rcv:MM =_TMP_Data_Rcv
gosub Snd_Rcv:YY =_TMP_Data_Rcv
HIGH CS_RTC
SS = BCDTOBIN SS 'Bit of converson of BCD to Decimal
NN = BCDTOBIN NN
HH = BCDTOBIN HH
DD = BCDTOBIN DD 'Bit of converson of BCD to Decimal
MM = BCDTOBIN MM
YY = BCDTOBIN YY
'write out the values
'sertxd(#SS,":",#NN,":",#HH,cr,lf)
aWord=HH
sertxd(":")
Aword= NN
sertxd(":")
aWord=SS
sertxd(" ",#DOW," ")
aWord=DD
sertxd("/")
aWord=MM
sertxd("/")
aWord=YY
Sertxd(cr,lf)
pause 2000
Snd_Rcv:
' Send Receive Data With Spi Clock
For _Tmp_2=1 to 8 ' 8 bit Frame
LOW CLK
'Send Data MOSI ------------------------------------
_Tmp_1=128
_TMP_bit=_Tmp_Data_Snd & _Tmp_1
_Tmp_Data_Snd=_Tmp_Data_Snd<<1
IF _TMP_bit = 128 then
HIGH MOSI
Else
LOW MOSI
Endif
'Receve Data MISO ------------------------------------
High CLK
_Tmp_Data_Rcv=_Tmp_Data_Rcv<<1
IF MISO = 1 then 'MOSI
_Tmp_Data_Rcv=_Tmp_Data_Rcv+1
Endif
Next _Tmp_2 ' Next Bit of Frame
RETURN
'Pad to left with 0
SerTxdWriteWord00000:
B0= aWord / 10000
B0 = B0 + 48
SerTxd (B0) ; output 10 thousands value data
SerTxdWriteWord0000:
aWord = aWord //10000
B0= aWord / 1000
B0 = B0 + 48
SerTxd (B0) ; output Thousands value data
SerTxdWriteWord000:
B0= aWord / 100
B0 = B0 + 48
SerTxd (B0) ; output Hundreds value data
SerTxdWriteWord00:
aWord = aWord //100
B0= aWord / 10
B0 = B0 + 48
SerTxd (B0) ; output Tens value data
SerTxdWriteWord0:
aWord = aWord //10
B0= aWord
B0 = B0 + 48
SerTxd (B0) ; output units data
RETURN
