I’ve added a DS3232 RTC (http://datasheets.maxim-ic.com/en/ds/DS3232.pdf) to my picaxe project , and everything’s working supper, except when removing power to the Vcc pin of the DS3232. When I put power back on this pin, the time goes back to midnight, January 1, 2001. I can’t get the battery backup working.
I’ve re-checked the circuit from battery to the Vbat pin and ground. I’ve even changed battery source. I can disconnect the PICAXE from the 5V+ source and the RTC works fine when reconnecting power to the PICAXE. The only thing I’m wondering about now is that I have two floating pins on the DS3232, the 32KHz pin, and the RST (i.e. reset) pin. I can't see why these would prevent battery backup.
