I am attempting a 'meter clock' with a 14M2 and DS1307. The datasheet says: "Battery input for any standard 3V lithium cell or other energy source. Battery voltage must be held between 2.0V and 3.5V for proper operation."Yes, you must connect Vbat to Gnd if no backup battery is connected.
You are missing something - page 6I am attempting a 'meter clock' with a 14M2 and DS1307. The datasheet says: "Battery input for any standard 3V lithium cell or other energy source. Battery voltage must be held between 2.0V and 3.5V for proper operation."
I couldn't see anything about connecting Vbat to GND without a battery. If I tie Vbat to GND it will be under the 2.0V spec. Did I miss something?
The '2.0V spec' is for proper operation when running from the battery.[hr][/hr]However, my claim of two thirds being the cut off point for communications is an exaggeration.If a backup supply is not required, VBAT must be grounded.
The nominal power-fail trip point (VPF) voltage at which access to the RTC and user RAM is denied is set by the internal circuitry as 1.25 x VBAT nominal.
Weird. I have occasionally had this happen - at least the DS1307 survives (in my case). My guesses for how it could possibly happen are that there could be a hairline short between tracks on stripboard, could be some strange oscillation in the circuit causing the chip to misbehave or it could be because of latch-up.Well..... It's a few minutes later and I am here to tell you that if you send Vbat to GND on my project things get really hot and smelly in a hurry.
The RTC and 5V regulator were hot to the touch.
I know that everyone always says their wiring is correct, so I may as well join the pack...Then I think, unfortunately, you have a wiring error
1. The AXE091 has both a DS1307 socket and an EEPROM socket.snipped
I am stopping for the day, but one more question first:
The AXE091 dev board and the PICAXE RTC wizard seem to suggest the 24LC16B EEPROM is required.
Is the EEPROM required to have the D1307 function with the PICAXE?
I can see that nothing is connected to Vbat on breadboard. It is clearly floating. If I add a wire that brings Vbat to GND, then *hot*.
Now that I have gotten that out of my system, I will go recheck the wires.
2. Are you getting your Wizards in a twist? See pics.
3. (from next post) OK, now perhaps post a High quality photo of your setup.
The DS1307 can be set without an EEPROM.
e
Agreed. As I mentioned in post #15 (with your reply) when I connected Vbat to GND things got "smelly" and the RTC and 5VDC regulator got hot hot.The Vbat pin of the DS1307 appears to not be connected.
I wish I could say exactly. Sometimes what we learn is doing it again fixes things.So.... good... what was wrong?... we learn from each others' mistakes [sometimes!]
