Rickharris
This is just a comment that may be helpful to others - i got an AXE33 display and clock module out today and set out to connect up to demonstrate to a student - Despite having done this several times from a picaxe28 board the )* refused to drive the display - or the display refused to display. Everything double and tripple checked.
Long story shortened the Picaxe 28 uses a 6 volt power source but the 08 is only 4.8 volts - Not enough to get the display running.
Even with the protection diode shorted as suggested in the data sheet the display refused to work until I connected a 6 volt battery pack to the display with a common ground to the 08 board which ran from it's 4.8 volt batter pack.
All worked fine but potentially very frustrating if you don't:
a) read the data sheet fully
b) don't have the test equipment to see what is a happening.
c) have the patience to stick at it until you resolve the problems
Hope this helps someone in the future and save pulling any more hair out.
