Yes, DISCONECT will definitely stop downloads being recognised, will require a hard reset for subsequent downloads.
Note that DISCONNECT is only required if using the Download Serial In for receiving serial data (SERRXD) or you have a button or something else connected to that pin.
You don't need a DISCONNECT just to use SERTXD or to use the Download Serial Out pin to control LED's, Piezos, relays etc.
