NoEinstein
On page 230 of the PicAxe Manual 2 for the sleep command it says: "Some PICAXE chips support the disablebod (enablebod) command to disable the brown-out detect function. Use of this command prior to a sleep will considerably reduce the current drawn during the sleep command."
I was wondering if using disablebod might also help save power in a system that is programmed to nap about 2 out of every 3 seconds or so. Would it be worth it? Or is there something about nap that is different from sleep so that power would not be saved?
Thanks.
Thanks.
