Does Blockly for Chrome work with the PICAXE-18M2?
coparu67
Hi
Blockly for Chrome v1.2.0 (Win7)
I check the PICAXE type and the app says "Hardware found: PICAXE-18M2"
I create a very simple program
I try to Program my PICAXE-18M2 and the app says "Error from compiler. Error: Incorrect hardware connected - PICAXE-18M2 (expected PICAXE-18M2+)
It appears that the Blockly App requires the newer 18M2+ ( Firmware D.x ) and the older 18M2 ( Firmware 2.x ) is not supported. Will need to investigate further to obtain a definitive response.
Although Blockly was designed for the latest generation chips you can force it to compile for the old obsolete legacy 18M2 instead by adding a BASIC block under the start block and then type this into the block
#legacy
