do - loop is thist a bug?
elektriker
symbol x = w5
pause 500
for x = 0 to 65438 step 777
     sertxd(#w5, cr, lf)
next x
sertxd("E N D", cr, lf)
This loop repeats 3 times !
geoff07
When I use the PE5 simulator it works as expected. Some more info regarding your test conditions would help.
Seems to work as expected for me in PE5 (5.5.6) and PE6.
I do note your post is entitled "do - loop is this a bug?" yet there is no do-loop in the code.
elektriker
hippy you are right, the title shot be "for-next is this a Bug?".
With Simulator PE 5.5.6 and PE6 it works right (0-84) ,
but when I prog. the Chip 08M2+ or 14M2 the Loop repeats 3 times * 84 (0-252) see the Txtfile.
Please have a look to the files and prog a real Chip.
Thanks
Werner
Thanks for clarifying.
It does seem there is a difference between how simulation and a real chip handles wrap-round overflow in a FOR-NEXT.
srnet
Is it the case that the simulator exits the for\next loop when the 'to' limit is exceeded, rather than overflowing and exiting when x actually does equal 65438 ?
For one thing, in case you are reading your output to make a determination of a problem, your code is printing out "#w5" instead of "x".
It is the chip that is correct:
 N=  81       62937
 N=  82       63714
 N=  83       64491
 N=  84       65268     <<<<<< 1
 N=  85       509
 N=  86       1286
None of these numbers, due to the overflow, are bigger than 65438, hence another 'loop' starts.
The PE6 simulator issue is that it is allowing (65268 + 777) > 65438 to return true, thanks for letting us know, we will correct this bug in the next software update.
It should be using ( (65268 + 777) AND 65535) > 65438
