DLL Error
trev324
I have a AXE110 Datalogger which happily runs the attached file but when I try to run it in VSM I get an error ; Internal Exception access violation in module 'AXEVSM.DLL'. I have stepped the file and at the line ' pause 300 ' get the LCD display ' V - + =y ' and the line ' gosub print12 ' is where the DLL error message appears.
Sorry for the delay.
You cannot 'readtemp12 3,w0' as input3 does not exist on 18X. Do not confuse physical leg numbers with the input/output numbering.
