donrecardo
Hi
I have just been playing with my new bargain serial OLED display.
Rev Ed were not kidding when they said if you use an OLED you wont
use LCD again. the brightness and contrast is fantastic and best of
all you can read it from pretty much any angle
Anyway, I have 3 questions...
I know that serout B.7, N2400,("A") will display a capital A on the display
just as serout B.7, N2400, (65) will also display the same capital A
Now suppose I read an ADC input into var b1 and lets say its value is 88
how do I get it to display the value of b1 " 88" rather than the character
"X" which relates to 88
second question is ...
The instruction sheet that came with it shows on appendix A the characters that
correspond to each Hex Value , except it seems to tell lies .
According to the sheet the Hex value DE ( dec 222) should give the omega symbol
but it doesn't . and many of the others seem to be wrong too
It even shows characters for FD,FE and FF , but surely that must be wrong as
253, 254 and 255 are command codes.
Is there a data sheet that gives the true characters that I will display for each
character code?
Lastly , the Appendix A shows 00 to 0F to be CG Ram locations which I think might be
areas where we can store and retrieve 16 user designed characters ? but I can see nothing
on the supplied sheet to say how to load or read these , Is there a manual /data sheet that explains this ?
Regards
Don
character code?
Regards
Don
