Hello,
I am just looking for some help regarding the final part of my project at college. Using a IR sensor (IR LED, Phototransistor) I am feeding the pulses picked up from reflective markers on the motor disc into the 18M2 Project Board using the COUNT command;
count irsensor, 1000, w1; ;count pulses from motor over second
Depending on the amount of pulses picked up from the markers with varying speed, I am looking to display an RPM value on my LCD screen, with a varying speed condition (Standstill, Underspeed, Normal, Overspeed).
Currently I am seeing a smooth transition through the conditions when I adjust the speed the motor, however the value that is being displayed on the motor is pulses per second rather than RPM. On my motor there are 9 reflective markers per revolution, I have attempted to write a formula based on the variable: (w1=w1/9*60) However the LCD doesn't appear to respond correctly. My program is relatively short:
initiate:
pause 500
serout LCD, N2400, (254,1) ; clear display for startup
serout LCD, N2400, (254, 128) ; move to start of first line
serout LCD, N2400, (" Shaft RPM ") ; Print message Shaft RPM
pause 5000
serout LCD, N2400, (254, 192) ; move to start of second line
serout LCD, N2400, (" RPM:",#w1) ; display pulse values
OVERSPEED:
if w1 < 24 then NORMAL ; less than 25 pulses = normal
serout LCD, N2400,(254,128) ; first row of the first line
serout LCD, N2400,(" Overspeed ") ; print message
goto main ; return to start
NORMAL:
if w1 < 14 then UNDERSPEED ; less than 14 pulses = underspeed
serout LCD, N2400, (254, 128) ; first row of first line
serout LCD, N2400, (" Normal ") ; print message
UNDERSPEED:
if w1 = 0 then STANDSTILL
serout LCD, N2400, (" Underspeed ")
STANDSTILL:
serout LCD, N2400, (" Standstill ")
Is there any way to display RPM rather than pulses per second? The model of motor I'm using is very old, I have emailed the company with regards to specs but they couldn't help. Its a DC permanent magnet servo motor, I am adjusting the speed with a varying power supply (0-15V).
Thanks a lot in advance
Steven
initiate:
pause 500
pause 5000
OVERSPEED:
NORMAL:
UNDERSPEED:
STANDSTILL:
Steven
