P PaulRB Senior Member Apr 25, 2013 #1 If I set up hwpmD (which is on b.5 on 14m2), and then subsequently use dirsB to set the other pins except b.5 as outputs, then use pinsB to set data on those pins, will the pwm continue to operate unaffected? Thanks, Paul
Technical Technical Support Staff member Apr 25, 2013 #2 Yes. the pwm 'overrides' any dirs/pins settings
hippy Ex-Staff (retired) Apr 26, 2013 #5 PaulRB said: Does same apply to pwmout and hpwm? Click to expand... Yes, same applies.
