A diode is aCan someone explain to me what the difference is between a diode and a rectifier
The TV station I worked at long, long ago used a cage full of mercury vapor rectifiers to deliver 5800 volts DC at 10 amps to power the 50KW video transmitter. The rectifier cage was probably 8 feet on each side and 8 feet high. This was in the days when TV transmitters actually shut down at night (after the Late Movie). The mercury vapor rectifiers had a timer for the filaments that turned them on some 30 minutes before morning turn-on of the transmitter - it took that long for the big rectifiers (several feet tall) to reach operating temperature.the old mercury arc rectifiers are amazing to watch, mesmorising.
Have a look for them on you tube.
They used to be used to provide power for the high power lamps used in cinema projectors.
Nope. You haven't got it yet.Great stuff. thanks all. So as I understand it, rectifiers are best at converting AC to half wave DC and diodes like the voltage already DC recified.
Probably better off on a different forum!.... years ago thongs where those foot appliance they now call flip-flops. So dare I ask what a thong is now or is that for a new thread?
wrecked 'im? it bloody near killed 'imAs explained in the link in Post#2 I thought .... ?
"Rectifier" also has the advantage of easily being changed into a rude word which amused schoolboys of Stan's (and my Dad's) era.
Rectumfrier.
It's known as a fungal infection and you can get a cream for that :>Mmm- "The thong has ended but the malady lingers on" ?
i vaguely remember one of those in an ancient car battery charger. use longer selenium for voltage thicker selenium for current i read that somewhere. i think i was 8 or 10 at that time so i didnt know what it wasI just read through all of this thread and didnt see anyone mention
selenium stick rectifiers . Lots of little square plates with a bolt through the middle . looking like a heatsink.
Surely I am not the only one old enough to remember those
Don
And you had to cautious if replacing a selenium rectifier with a "new" silicon rectifier - the voltage under load coulod be appreciably higher (for tube type power supplies).I recall them (& their relative inefficiency) well -about 1965 in fact! Compare them beside a modern superior Si FWB in the picture.
