Hi all,
I've made a few picaxe curcuits but my knowledge of electronics is a bit sketchy and I've come up against a problem while making a new picaxe circuit that involves a diode.
As you will see in the attached diagram the axe is powering led1 via a 330r resistor, however led2 which is being fed via a diode will not light until I disconnect led1.
I can work around this by using a spare output on the axe but I want to know why led2 won't light when led1 is lit.
As I understand it, diodes allow current to flow one way but not the other, so I can see no reason for led2 not to light up at the same time as led1.
I'd be grateful if someone could advise
Rgds,
Sid
Rgds,
Sid
