Hello again guys!
Working on this DHT11 again, and would like to add my Axe033 display module to it.
I have been following along in this thread for the DHT11 code and circuit-
http://www.picaxeforum.co.uk/showthread.php?22382-DHT11-DHT22-on-a-PICAXE-Solved-in-software&highlight=dht11
And also-
http://www.picaxeforum.co.uk/showthread.php?19459-DHT11-Humidity-Sensor&highlight=dht11
I am currently using a 40x2, and do get stable readings in the terminal window.
What I am aiming to do now is get that information onto my display.
I am using this code provided by Goeytex( I believe?)
Now, I figured all I needed to do was use serial out A.4 on the 40x2 that would give me my display, but it doesnt.
Heres the code I tried most recent-
I also tried C.0,C.6 but to no avail.
Do I need to modify my circuit at all or does the problem lie in my code?
Also, While I have your attention- What is the difference between serout and Hserout?
Thank you!
And also-
'* PICAXE BASIC FOR READING DHT-11 WITH PICAXE 28X2 *
#picaxe 40x2
#no_table
setfreq em64
high c.0
init:
symbol bit_num = b0
symbol humidity = b2
symbol temperature = b4
symbol numbits = b6
GET_DATA:
pause 12500 'Stabilize 2 seconds
setfreq em64 'Must read Sensor @ 64mhz !
ptr = 1 'Set Scratch Pad pointer to "1"
pulsout c.0, 35000 'Req Data from DHT-11
pulsin c.1,1,@ptr 'First bit (will be ignored so don't increment)
'Humidity bits (Integer)
pulsin c.1,1,@ptrinc 'SP Location 1
pulsin c.1,1,@ptrinc 'SP location 2
pulsin c.1,1,@ptrinc 'SP location 3
pulsin c.1,1,@ptrinc 'SP location 4
pulsin c.1,1,@ptrinc 'SP location 5
pulsin c.1,1,@ptrinc 'SP location 6
pulsin c.1,1,@ptrinc 'SP location 7
pulsin c.1,1,@ptrinc 'SP location 8
'Humidity Bits (Decimal)
pulsin c.1,1,@ptrinc 'not used with DHT11
'Temperature bits (Integer)
'Temperature Bit (Decimal)
pulsin c.1,1,@ptrinc 'Not used
'Checkusm bits
setfreq em32 'Reduce Frequency for Serial @38400
pause 100
'******* 'For testing / debugging *****************
numbits = ptr - 1
Sertxd ( "Received: ",#Numbits," Bits",cr,lf,cr,lf)
Sertxd ("Humidity Vals: ")
for ptr = 1 to 8
sertxd (#@ptr, " ")
next
sertxd(cr,lf,cr,lf)
sertxd ("Temperature Vals: ")
for ptr = 17 to 24
sertxd (#@ptr, " ")
next
Sertxd (Cr,lf,cr,lf)
'*** Process 8 Humidity bits ***
Humidity = 0 ' Clear humidity variable B2
For ptr = 1 to 8 'Read bits 1 - 8 (ignoring bit 0)
bit_num = 8 - ptr 'Bit# 7 - 0 for Humidity Var B2
if @ptr > 90 then
setbit humidity,bit_num 'Set b2 bit(x) to 1
if @ptr < 60 then 'Set b2 bit(x) to 0
clearbit humidity,bit_num
Next
'Don't care about bits 9- 16
'*** Process 8 temperature bits ***
Temperature = 0 'Clear Temperature variable B4
For ptr = 17 to 24 'Read DHT-11 bits 17 - 24
bit_num = 24 - ptr 'Bit# 7 - 0 for Temperature Var B2
if @ptr > 90 then 'Set b4 bit(x) to 1
setbit temperature,bit_num
if @ptr < 60 then 'set b4 bit(x) to 0
clearbit temperature,bit_num
Next
'**** Skipping Checksum ****
'**** Convert C to F****
symbol F=w0
symbol C1=Temperature
F=9*C1/5+32
'*** Display data ***
sertxd ("Temperature: ",#w0,176,"F",cr,lf)
sertxd ("Rel Humidity: ",#humidity,"%",cr,lf,cr,lf)
GOTO GET_DATA 'LOOP
serout A.4,N2400,(254,128) ; move to start of first line
serout A.4, N2400,(254,1)
pause 30
serout A.4, N2400,("Temperature: ",#w0,176,"F",cr,lf)
serout A.4,n2400,(254,192)
serout A.4,n2400,("Rel Humidity: ",#humidity,"%",cr,lf,cr,lf)
Thank you!
