I have a 28X1 chip which drives a serial LCD (via Andersons #118 chip) but I want to wait a short while (around 10 secs) after bootup until the LCD actually has power applied to it.
The LCD power source is the same 5V as the PICAXE and I was thinking of using a 5V mini relay which is switched by an output pin on the PICAXE to turn on the LCD (draws ~100mA when on). So a few questions :
- Do I still need a transistor and diode etc (as per "Standard Circuits 3" section of PICAXE Manual 3 pdf) even though the PICAXE & LCD use 5V. Note : The LCD will never be turned off once it is powered on (until the entire cicruit is powered down)
- Is there a better way to do this than a relay (delay power-up of the LCD)?
Alan in Oz
Alan in Oz
