With a PicAXE 08M2 version 4A, I am unable to get both a Debug window and Terminal window to load. I wanted to use the terminal program to control stopping to examine the debug window, then send a char to serrxd to let the program continue on (sort of like breakpoints which I believe only work in the simulation), and the program is FAR to large and complex to simulate (778 bytes of complex instructions plus 100 bytes EEPROM data). Any suggestions? Can breakpoints be set while running the program, or is there any way to stop execution of the program when it hits a debug command? In fact, I have to connect + voltage while the editor attempts to download program or it just hangs with a download failure. I CAN live with that, but it is a bit of a nuisance!
