Hi Diogo, Welcome to the PICAXE Forum.
Several years ago, I had a summer-time overheating problem in an electronic instrument (PVR) and developed this code to drive a DC motor/fan to help keep it cool.
You probably already understand how PWM works. The PWM source (PICAXE in this case) switches quickly between 0v and 5v (representing logic 0 and 1), controlling the amount of '1' versus '0'. This varies the
average amount of energy being delivered to the load and can control the brightness of a light or the speed of a motor.
Motors have characteristics that you need to consider. Once a motor is running, it needs less energy than if it has to be started from its resting position. So, when starting the stationary motor, I give the motor pin a longer pulse at full power to get the motor's armature moving before turning on the PWM control.
You will not be able to connect a motor directly to a PICAXE but will need to use a bipolar transistor, darlington transistor or MOSFET to handle the higher current and/or voltage required by a motor. For interfacing circuitry, refer to Manual 3, "Output Devices 5 - Motors".
As I said before, this code was written several years ago for an older PICAXE model (14M) as may need some minor command syntax changes to make it work on a more modern PICAXE.
[color=Green]'PVR Cooler controlled by a PICAXE 14M2 and an instrument cooling fan.[/color]
[color=Navy]#Picaxe [/color][color=Black]14M[/color]
[color=Navy]#Terminal 4800[/color]
[color=Green]'
'Inputs have the prefix 'i'[/color]
[color=Blue]Symbol iPVRTempSense [/color][color=DarkCyan]= [/color][color=Navy]0 [/color][color=Green]'14M Leg 7 DS18B20 Sensor for PVR temperature[/color]
[color=Blue]Symbol iAmbientSense [/color][color=DarkCyan]= [/color][color=Navy]4 [/color][color=Green]'14M Leg 3 DS18B20 Sensor for room temperature
'14M Port C: B/W used as outputs[/color]
[color=Blue]Symbol oPWM_Fan [/color][color=DarkCyan]= [/color][color=Blue]C.2 [/color][color=Green]'14M Leg 5 Port C5 used as PWMOut output - called '2'
'Outputs have the prefix 'o'[/color]
[color=Blue]Symbol oLEDBooted [/color][color=DarkCyan]= [/color][color=Navy]5 [/color][color=Green]' Leg 8 LED to indicate PICAXE has (re)booted
'Variables - Byte variables start with 'b'; Word Variables start with 'w'[/color]
[color=Blue]Symbol [/color][color=Purple]bAmbientTemp [/color][color=DarkCyan]= [/color][color=Purple]b4[/color]
[color=Blue]Symbol [/color][color=Purple]bPVRTemp [/color][color=DarkCyan]= [/color][color=Purple]b5[/color]
[color=Blue]Symbol [/color][color=Purple]bTempDiff [/color][color=DarkCyan]= [/color][color=Purple]b6 [/color][color=Green]'Temperature difference (Ambient vs inside electronic instrument)[/color]
[color=Blue]Symbol [/color][color=Purple]bFanSpeed [/color][color=DarkCyan]= [/color][color=Purple]b7[/color]
[color=Blue]Symbol [/color][color=Purple]bFanOn [/color][color=DarkCyan]= [/color][color=Purple]b8[/color]
[color=Green]'
'Constants[/color]
[color=Blue]Symbol False [/color][color=DarkCyan]= [/color][color=Navy]0[/color]
[color=Blue]Symbol True [/color][color=DarkCyan]= [/color][color=Navy]1[/color]
[color=Green]'
'[/color]
[color=Black]Init: [/color][color=Blue]High oLEDBooted
Pause [/color][color=Navy]3000 [/color][color=Green]'Indicate PICAXE has booted or rebooted
[/color][color=Blue]Low oLEDBooted
PWMOut oPWM_Fan[/color][color=Black], [/color][color=Navy]49[/color][color=Black], [/color][color=Navy]0 [/color][color=Green]'Ensure PWM pin is output (0% PWM Duty)
[/color][color=Blue]Do
[/color][color=Green]'Readtemp12 AmbientSense, w5 'ReadTemp12 not supported by FW ver 9.C
[/color][color=Blue]Readtemp iAmbientSense[/color][color=Black], [/color][color=Purple]bAmbientTemp
'Readtemp12 PVRTempSense, w6 'PVRTemp
[/color][color=Blue]Readtemp iPVRTempSense[/color][color=Black], [/color][color=Purple]bPVRTemp
[/color][color=Purple]bTempDiff [/color][color=DarkCyan]= [/color][color=Purple]bPVRTemp [/color][color=DarkCyan]- [/color][color=Purple]bAmbientTemp[/color][color=Green]'Assumes PVR temperature will be hotter or equal to ambient
[/color][color=Blue]If [/color][color=Purple]bPVRTemp [/color][color=DarkCyan]> [/color][color=Navy]35 [/color][color=Blue]Then [/color][color=Green]'Over 35deg C
[/color][color=Blue]PulsOut [/color][color=Navy]1[/color][color=Black], [/color][color=Navy]1000
[/color][color=Blue]PWMOut [/color][color=Navy]2[/color][color=Black], [/color][color=Navy]49[/color][color=Black], [/color][color=Navy]200 [/color][color=Green]'Maximum speed
[/color][color=Blue]ElseIf [/color][color=Purple]bTempDiff [/color][color=DarkCyan]> [/color][color=Navy]0 [/color][color=Blue]Then
If [/color][color=Purple]bFanOn [/color][color=DarkCyan]= [/color][color=Blue]False Then
[/color][color=Purple]bFanOn [/color][color=DarkCyan]= [/color][color=Blue]True
High oPWM_Fan [/color][color=Green]'Burst of 12v ensures fans starts properly
[/color][color=Blue]Pause [/color][color=Navy]300 [/color][color=Green]'300mS burst
[/color][color=Blue]Low oPWM_Fan
EndIf
If [/color][color=Purple]bTempDiff [/color][color=DarkCyan]> [/color][color=Navy]7 [/color][color=Blue]Then [/color][color=Green]'7 degrees C up means full speed: limit it to 7
[/color][color=Purple]bTempDiff [/color][color=DarkCyan]= [/color][color=Navy]7
[/color][color=Blue]EndIf
[/color][color=Purple]bFanSpeed [/color][color=DarkCyan]= [/color][color=Purple]bTempDiff [/color][color=DarkCyan]- [/color][color=Navy]1 [/color][color=DarkCyan]* [/color][color=Navy]25 [/color][color=DarkCyan]+ [/color][color=Navy]40[/color][color=Green]'Gives 7 steps: 40, 65, 90, 115, 140, 165, 190
[/color][color=Blue]PWMOut oPWM_Fan[/color][color=Black], [/color][color=Navy]49[/color][color=Black], [/color][color=Purple]bFanSpeed [/color][color=Green][PLAIN]'FanSpeed=100=50%; FanSpeed=200=100%; Eg pwmout 2 , 49, 100 '[50%][/PLAIN]
PWMOut oPWM_Fan[/color][color=Black], [/color][color=Navy]49[/color][color=Black], [/color][color=Navy]0 [/color][color=Green]'Just put here during development
EndIf
[/color][color=Blue]Pause [/color][color=Navy]4000
[/color][color=Blue]Loop[/color]
