I'm not sure what hysteresis means.
When an inductor/coil is disconnected (and I am going to explain it when it is mechanically disconnected), a large voltage difference builds up between the leads of the inductor by the residual current and/or magnetism, and it may arc across the air-gap between the disconnecting switch contacts or wires - in milliseconds or microseconds.
I think wires always have a number of fFs (0.001s of pFs) of capacitance.
Hysteresis is when a point on operating curve is in a different position depending on which direction you come from. This is typical for many magnetic properties.
Any conductor whatsover has both capacitance and inductance.
Test question:-
Design an LC circuit to resonate at a frequency that would give off light.
Calculate suitable L and C values. Then design the inductor and capacitor.
Will come upon an interesting problem. (great shame, would be fun to do!).
Inductors don't like a change in current. They will whatever they can to prevent it. If that means creating a stonking great big voltage to jump across the junction of your tranistor (or switch) when it turns off, then is that exactly what they will try to do.
The only reason the current in an inductor ever stops is because the energy gets dissipated. Either as I^2.R in the conductor, as load bang with light show as a spark or nicely into a snubber or freewheeling diode.
Make one out of superconducting material and the current will continue forever.
That's how efficient switching regulators work, by using the residual current stored in the inductor to also put power into the output via a freewheel diode (schottkey in this case), after the transistor switches off when the output voltage reaches the selected level. Then when the output voltage falls below the selected voltage sharp, the transistor switches on again.
This transfers 85-90% of the input power wattage to the different- voltage output, unlike linear regulators, where the percentage is less.
Capacitors store voltage for a long time (about an hour depending on capacity).
Inductors store current (but dissipates it a lot more quickly).
No, not really. Switchers work by using inductance as storage medium using different rates of current change to produce different voltages. 'Resisdual' current is something you really don't want in a switcher. It is current which cannot be converted (it's residual) and is therefore lost.
A high efficiency switcher does NOT use diodes on the output. These are only used in low efficiency switchers. High efficiency ones use active rectification. 75% of the losses in a typical diode clamped switcher are lost in the diode.
The amount of time a capacitor can store energy has absolutely nothing whatsoever to do with its capacity. It will only lose charge if it has an internal leakage current or external load. (such as putting a meter on it to measure the voltage).
Is this why I keep getting the yellow messages in PICAXE VSM saying "SPICE: transient GMIN stepping at time t=######"? SeeToo many iterations without convergence.
No. AFIK, the models in VSM do not simulate transients unless you specifically include items such as parasitic inductance in your model.
Too many iterations means the model is not converging to a steady state for your model. This may be because your model is too complex or has some errors. (reverse polarised electrolytic caps can cause it). There are parameters you can configure to help combat this issue but I am not familiar enough with it to advise on how to make those changes.
