This may sound a little picky but it doesn't hurt to get it right.
There has been considerable reference to "DB9" connectors such as the serial connector.
The correct terminology is "DE9". The first letter (D) referrs to the connector style, the second to the standard shell or body size, ie: E=9, A=15, B=25, C=37, D=50. Thus reference to "DB9" indicates a 25 pin shell size with 9 pins. This terminology became desirable with the introduction of high density connectors, for instance the video connector is a 15 pin in a 9 pin body style, it thus becomes a "DE15". Similarly we have a "DC62", "DD70" and so on.
Finally, "D" connectors have a finite life. From memory a better quality gold plated pin has a guaranteed life of only 50 insertions if flash plated and 200 insertions if a heavier gold finish is used (forget the actual gold thickness). Also rolled and machined pins differ in their lifespan.
The above information can be obtained from the "Connector Encyclopaedia" (which the average person is very unlikely to have access to, VERY VERY expensive)or detailed manufacturers specifications.
As the average hobyist probably uses the most economical connector he (or she)can get the possibility of some of the intermittent problems reported being due to a worn out "D" connector maybe should not be overlooked.
Cheers BobR
Cheers BobR
