Current sensing
Roseandthistle
Hi all.
I'm working on a project that is 90% complete. It's the last 10% that's giving me grey hair. I'll try and lay this project out first then ask the questions I need help with.
Project: Sequential battery charger. I've got a 6vdc / 12vdc with charge and float. Charge is connected to PINA.2 of the picaxe with an opto-isolator.(works)
12 relays, transistor driven, diode protected. (works)
4x20 lcd, 1 ADC input, ACS 712 Hall effect current sensor, 28X2 Picaxe
Scope: The program I've got so far, cycles through the relays one at a time with a pause in between. If PINA.2 goes high (battery is charging) then an interrupt occurs. When this condition clears then the program continues on. Until, the next battery needs charged.
Problem: In searching the posts and internet, I found that most Allegro Microchip's , Hall Effect chips are 6 months from production. I did find an ACS 712 breakout board at Sparkfun.com. The spec sheet says that with no current going thru, an output will be 2.5vdc. I've tried it, it's correct. The spec sheet also states that the chip is rated for 5 Amps. I only need 500 mAmps. http://www.sparkfun.com/datasheets/BreakoutBoards/0712.pdf
Now I've got an input to adcsetup 0.Readadc10 0 ,SensADC
W1= SENSADC - REFADC * OFFSET / RESOL 'W0 - 512 * 98 / 20
serout A.1,BR,(254,151,".",#W1)
Questions: First of all, Am I thinking the math correctly?
2: Where do I put the READADC10 (sub routine) so it will update regardless of anything else going on.
3: Can I use SELECT CASE with READADC10 to make an lcd backlight turn off, or clear an interrupt, at a predetermined reading?
4: Bar graph. I would like to add a bargraph to line 4 of the lcd. Is there an easy way to do this? Starting out left (-)and increasing to the right as the mAmps decrease.
Thanks in advance.
#PICAXE 28X2
'#COM 4
#SLOT NUMBER 0
#FREQ M4
'OUTPUTS:
 'C4	RELAY1
 'C5	RELAY2
 'C6	RELAY3
 'C7	RELAY4
 'B0	RELAY5
 'B1	RELAY6
 'B2	RELAY7
 'B3	RELAY8
 'B4	RELAY9
 'B5	RELAY10
 'B6	RELAY11
 'B7	RELAY12
 'A1  LCD
 'C0	MANUAL MODE 6VDC
 'C1	6VDC MODE
 'C2	12VDC MODE
 'C3	MANUAL MODE 12VDC
'INPUTS:
 'A0	OP AMP ADC
 'A3  CHARGE
 'A2	FLOAT CHG
'SET PINS:
let dirsA = %11110010 'SET PINS AS OUTPUTS
let pinsA = %00001111 'SET AS OFF, A0,A2 INPUT
let dirsB = %11111111 'SET PINS AS OUTPUTS
let pinsB = %00000000 'SET AS OFF
let dirsC = %11110110 'SET PINS AS OUTPUTS
let pinsC = %00000000 'SET AS ON, C1, C2 OUTPUTS
let adcsetup = 0
'SET CONSTANTS/VARIABLES
SYMBOL BR = T9600
SYMBOL TIMEOFF = 1000
SYMBOL SENSADC = W0
SYMBOL REFADC = 512
SYMBOL OFFSET = 98
SYMBOL RESOL = 20
'LCD:
INIT:
serout A.1,BR,(254,0X7C,140)'Backlight brightness control 128off,140 40%,150 73%,157 100%
serout A.1,BR,(254,0X01) 	'Clear and wait
MAINLCD:
serout A.1,BR,(254,128,"  SEQUENTIAL")
serout A.1,BR,(254,192," BATTERY CHARGER")
serout A.1,BR,(254,148,"  MODEL 1200")
serout A.1,BR,(254,128,"Battery Number")
serout A.1,BR,(254,188,"Is now charging at")
serout A.1,BR,(254,160,"mAMPS")
BARGRAPH:
MAIN:
      HIGH  C.4 serout A.1,BR,(254,145," 1")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW C.4
	HIGH  C.5 serout A.1,BR,(254,145," 2")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW C.5
	HIGH  C.6 serout A.1,BR,(254,145," 3")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW C.6
	HIGH  C.7 serout A.1,BR,(254,145," 4")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW C.7
      HIGH  B.0 serout A.1,BR,(254,145," 5")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.0
	HIGH  B.1 serout A.1,BR,(254,145," 6")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.1
      HIGH  B.2 serout A.1,BR,(254,145," 7")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.2
	HIGH  B.3 serout A.1,BR,(254,145," 8")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.3
	HIGH  B.4 serout A.1,BR,(254,145," 9")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.4
	HIGH  B.5 serout A.1,BR,(254,145,"10")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.5
	HIGH  B.6 serout A.1,BR,(254,145,"11")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.6
	HIGH  B.7 serout A.1,BR,(254,145,"12")
      GOSUB INTERRUPT
	PAUSE TIMEOFF
	LOW B.7
     GOTO MAIN
 'SUBROUTINES
INTERRUPT:
 	READADC10 0,SensADC
 	IF PINA.3 = 1 THEN INTERRUPT  'IF A BATTERY IS DETECTED THEN
 	PAUSE 2000                    'STOP UNTIL BATTERY
 	SETINT %00001000, %00000000, A'IS CHARGED THEN CONTINUE
 	RETURN
premelec
Hi, I haven't got time to go into this in detail but mention that Re: 2. your READADC must be inside the repeating loop not just in a subroutine - It can also have another read inside a subroutine to watch what's happening... But the original ADC value to decide to go to the sub must be in the main loop.
There are high side current sense units which translate a shunt voltage [could just be a length of wire] to a low side current or voltage with known transfer ratio [ca x100] - look at Diodes Inc and Analog Devices listings for instance. These might help you out as they aren't too expensive - depends on how your charger and batteries are set up.... good luck - should work out well and it looks like you are headed in the right direction...
premelec
Two reasons to use Hall effect would be very low power loss even at high currents and complete electrical isolation from current bus being measured - it's not clear that these characteristics are required in this instance. I notice there are some Hall effect units on ebay.
manuka
-I found that most Allegro Microchip's , Hall Effect chips are 6 months from production. -
Your HE situation is hard to believe! And did I get it right- just a modest 500mA charge? What sort of batteries,budget & time frame are you wrestling with anyway? It's probably too simple for your needs, but how about at least considering the old skin flint method, whereby the voltage drop across a series 1 Ohm (or multiple/submultiple) resistor is measured. In 2006 I used this with great success to drive a modified bike computer display - Amps were registered as km/hr & A.h as km. Check here for the layout, here for the schematic,here for the code & finally (!) here for the feedback.
fernando_g
Rose;
You could also use a hall sensor from Honeywell. The CSLW6B1 is rated at 1 amp (would give you much better resolution than the ACS712) and it is available from Digikey.
