I have started to write a program to control a radio transceiver (FT817) with an 18X and having a keypad and LCD. So far I have the Lcd display working and the keypad routine gets key presses, converts them to ascii and sends them to the LCD. So far so good. Then I turn off the device, come back to it later and the program sets up the LCD but nothing happens with regard to key presses, it's as if there is a stop command just before the program goes off to the getkey routine. Debug doesn't work either.
Like I said, download the program and it works, powercycle the picaxe and it locks up after the first line is sent to the LCD. Any thoughts?
SYMBOL RS = 2 ; 0 = Command 1 = Data
SYMBOL E = 3 ; 0 = Idle 1 = Active
SYMBOL DB4 = 4 ; LCD Data Line 4
SYMBOL DB5 = 5 ; LCD Data Line 5
SYMBOL DB6 = 6 ; LCD Data Line 6
SYMBOL DB7 = 7 ; LCD Data Line 7
SYMBOL RSCMDmask = %00000000 ; Select Command register
SYMBOL RSDATmask = %00000100 ; Select Data register
SYMBOL counter = b3
SYMBOL Val = b6
SYMBOL Col = b7
SYMBOL Row = b8
SYMBOL Polin = b9
SYMBOL Pol = b10
SYMBOL get = b11
SYMBOL bite = b12
SYMBOL rsbit = b13
EEPROM $50,(0,0,0,0,0,1,4,7,14,2,5,8,0,3,6,9,15,10,11,12,13)
' lookup table for keypad
EEPROM $70,("VFO TOGL")
EEPROM $80,("FREQ.MHz") ' store the text in the EEPROM memory
EEPROM $90,("MODE 0-7")
'Start -----------------------------------------------------------
PowerOnReset:
GOSUB InitialiseLcd
DisplayFirstLine:
FOR get = $80 TO $87 'display the first message (FREQ.MHz)
READ get,bite
GOSUB SendDataByte
NEXT
MoveCursorToStartOfSecondLine:
bite = $C0
GOSUB SendCmdByte
GetEightKeyPresses:
for counter=1 to 8
gosub getkey
bite = Val + 48
Gosub SendDataByte
next counter
goto DisplayFirstLine
stop
FOR get = 16 TO 22
READ get,bite
GOSUB SendDataByte
NEXT
END
'Subs ---------------------------------------------------------------
InitialiseLcd:
FOR get = 0 TO 5
READ get,bite
GOSUB SendInitCmdByte
NEXT
' Nibble commands - To initialise 4-bit mode
EEPROM 0,( $33 ) ; %0011---- %0011---- 8-bit / 8-bit
EEPROM 1,( $32 ) ; %0011---- %0010---- 8-bit / 4-bit
' Byte commands - To configure the LCD
EEPROM 2,( $28 ) ; %00101000 %001LNF00 Display Format
EEPROM 3,( $0F ) ; %00001111 %00001DCB Display On,cursor on,flash on
EEPROM 4,( $06 ) ; %00000110 %000001IS Cursor Move
; L : 0 = 4-bit Mode 1 = 8-bit Mode
; N : 0 = 1 Line 1 = 2 Lines
; F : 0 = 5x7 Pixels 1 = N/A
; D : 0 = Display Off 1 = Display On
; C : 0 = Cursor Off 1 = Cursor On
; B : 0 = Cursor Steady 1 = Cursor Flash
; I : 0 = Dec Cursor 1 = Inc Cursor
; S : 0 = Cursor Move 1 = Display Shift
EEPROM 5,( $01 ) ; Clear Screen
RETURN
SendInitCmdByte:
PAUSE 15 ; Delay 15mS
SendCmdByte:
rsbit = RSCMDmask ; Send to Command register
SendDataByte:
pins = bite & %11110000 | rsbit ; Put MSB out first
PULSOUT E,1 ; Give a 10uS pulse on E
pins = bite * %00010000 | rsbit ; Put LSB out second
rsbit = RSDATmask ; Send to Data register next
RETURN
getkey:
let pins=0 'clear out pins
Pol=16
g1: pins=Pol
lookdown Pol,(0,16,32,64,128),Col 'compare Pol & values ->Col
Polin=pins 'input the pins value
lookdown Polin,(0,128,1,2,4),Row 'compare with values -> Row
if Row <>0 then exitgk
if Pol=128 then getkey ' if 0 no key pressed
Pol=Pol*2
goto g1
exitgk:
Col=Col*4 ' shift 2 places
Col=Col+Row+$50 ' then add to 'lower half' plus start of lookup table
debug
read Col,Val ' read key from table
e1: Polin=pins
if Polin <>0 then e1 ' wait til key released
