Electronics Learner 123
Well-known member
Hi Guys,
I have recently looked at this forum and others relating to controlling led strip ws2801 using a Picaxe chip, I have stumbled along this project here, this has really fascinated me and was wondering if there was a way to use an RTC to do the same thing, I have looked at the code that has been kindly distributed by the members of the Picaxe on how to code such things ,however, I don't understand it fully: is there a way to control 28 leds like this: (each number represents 1 led)
https://github.com/leonvandenbeukel/7-Segment-Digital-Clock/blob/master/7_Segment_Display with LED indexes 0 - 13 right segments - minutes.pdf
ps there will be dots in-between
EDIT: this is what I mean
Could I implement something like seen here: https://github.com/leonvandenbeukel/7-Segment-Digital-Clock/blob/master/DigitalClockV2.ino
PS. This guy does other codes but they are all written for Arduino.
Is there a way that I could create an array for the numbers and call them when necessary; is it possible to stack e.g. RTC splits time from 12:30 into ---> 1 2 : 3 0 and then ----> code finds leds needed to light a 1, in digit 2: led 1 and 2 and 7 and 5 and 4 and then offset this by 7 so that it appears in the second digit while taking into account the dots in the middle of the time.
PS what chips would be needed and how would I wire them (diagram pls) , ps. I am very new so please bear with me
Thanks in advance
Repository of the 7 segment digital clock I made as found on my youtube channel - leonvandenbeukel/7-Segment-Digital-Clock
github.com
Thanks in advance
