SET_EXPO:
let b7 = 0
let b6 = 0
let b5 = 0
let b33 = 0
serout C.3,N9600_16,(254,1)
pause 500
serout C.3,N9600_16,(254,128,"SET EXPOSURE TIME") ; sets the exposure time in hh/mm/ss format
serout C.3,N9600_16,(254,194,#b7," hours")
serout C.3,N9600_16,(254,150,#b6," minutes")
serout C.3,N9600_16,(254,214,#b5," seconds")
pause 100
gosub V7
pause 100
gosub V6
pause 100
gosub V5
pause 100
goto SET_INT
V7:
;V7,V6 and V5 are the variables
for b33 = 1 to 2 ; for the exposure times
gosub GKP
if key_value = 12 then let b7 = 0 return endif ;if no value wanted key in 12
if key_value = 11 then let b7 = 0
if key_value = 10 then goto SET_EXPO ;if incorrect key in 10 and go back to start
b7 = b7 * 10 + b1
if b7 < 10 then serout C.3,N9600_16,(254,194,"0",254,195,#b7) else
serout C.3,N9600_16,(254,194,#b7) endif
pause 30
next b33
V6:
for b33 = 1 to 2
gosub GKP
if key_value = 12 then let b6 = 0 return endif
if key_value = 11 then let b6 = 0
b6 = b6 * 10 + b1
if b6 < 10 then serout C.3,N9600_16,(254,150,"0",254,151,#b6) else
serout C.3,N9600_16,(254,150,#b6) endif
pause 30
next b33
V5:
for b33 = 1 to 2
gosub GKP
if key_value = 12 then let b5 = 0 return endif
if key_value = 11 then let b5 = 0
b5 = b5 * 10 + b1
if b5 < 10 then serout C.3,N9600_16,(254,214,"0",254,215,#b5) else
serout C.3,N9600_16,(254,214,#b5) endif
pause 30
next b33
SET_INT:
let b14 = 0
let b13 = 0
let b12 = 0
let b33 = 0 ; sets the interval time in hh/mm/ss format
pause 500
serout C.3,N9600_16,(254,128,"SET INTERVAL TIME")
serout C.3,N9600_16,(254,194,#b14," hours")
serout C.3,N9600_16,(254,150,#b13," minutes")
serout C.3,N9600_16,(254,214,#b12," seconds")
pause 100
gosub V14
pause 100
gosub V13
pause 100
gosub V12;
pause 100
goto FRAMESET
V14:
;V14, V13 and V12 are the variables
for b33 = 1 to 2 ; for the interval times
gosub GKP
if key_value = 12 then let b14 = 0 return endif
if key_value = 11 then let b14 = 0
if key_value = 10 then goto SET_INT
b14 = b14 * 10 + b1
if b14 < 10 then serout C.3,N9600_16,(254,194,"0",254,195,#b14) else
serout C.3,N9600_16,(254,194,#b14) endif
pause 30
next b33
V13:
for b33 = 1 to 2
gosub GKP
if key_value = 12 then let b13 = 0 return endif
if key_value = 11 then let b13 = 0
b13 = b13 * 10 + b1
if b13 < 10 then serout C.3,N9600_16,(254,150,"0",254,151,#b13) else
serout C.3,N9600_16,(254,150,#b13) endif
pause 30
next b33
V12:
for b33 = 1 to 2
gosub GKP
if key_value = 12 then let b12 = 0 return endif
if key_value = 11 then let b12 = 0
b12 = b12 * 10 + b1
if b12 < 10 then serout C.3,N9600_16,(254,214,"0",254,215,#b12) else
serout C.3,N9600_16,(254,214,#b12) endif
pause 30
next b33
FRAMESET: ; sets the number of exposures wanted
let w14 = 0
let b33 = 0
pause 50
pause 500
serout C.3,N9600_16,(254,128,"SET HOW MANY")
serout C.3,N9600_16,(254,192," EXPOSURES")
serout C.3,N9600_16,(254,151,#w14)
pause 100
gosub VW14
pause 100
goto SETRUN
VW14: ;VW14 is the variable for amount of exposures
for b33 = 1 to 4
gosub GKP
if key_value = 12 then let w14 = 0 return endif
if key_value = 11 then let w14 = 0
if key_value = 10 then goto FRAMESET
w14 = w14 * 10 + b1
serout C.3,N9600_16,(254,154,#w14)
pause 30
next b33
Return
SETRUN: ;shows the times inputted and to hit the # key to run
pause 500
serout C.3,N9600_16,(254,128,"EXP TIME -",254,139,#b7,254,141,":",254,142,#b6,254,144,":",254,145,#b5)
serout C.3,N9600_16,(254,192,"INT TIME -",254,203,#b14,254,205,":",254,206,#b13,254,208,":",254,209,#b12)
serout C.3,N9600_16,(254,148,"EXPOSURES -",254,160,#w14)
serout C.3,N9600_16,(254,212,"HIT THE # KEY TO RUN")
gosub GKP
loop until key_value = 12 ; 12 is the # key on keypad and will start the run sequencw when pressed
goto RUNNING
RUNNING:
pause 50
let timer = b5
let b55 = b7
let b54 = b6
let b52 = b14
let b51 = b13
;shows the times incrementing up in realtime
serout C.3,N9600_16,(254,1) ;and frames taken
pause 30
serout C.3,N9600_16,(254,128,"EXP TIME -",254,139,#b55,254,141,":",254,142,#b54,254,144,":",254,145,#timer)
serout C.3,N9600_16,(254,192,"INT TIME -",254,203,#b52,254,205,":",254,206,#b51,254,208,":",254,209,#timer)
serout C.3,N9600_16,(254,212,"COUNTER -",254,222,#w15)
pause 30
high CAMERA
settimer t1s_16
EXPO:
if timer = 0 and b54 = 0 and b55 = 0 then goto expo1
if timer = 0 and b54 = 0 then dec b55 let timer = 59 : let b54 = 59 endif
if b55 < 10 then serout C.3,N9600_16,(254,139,"0",254,140,#b55) else
serout C.3,N9600_16,(254,139,#b55) endif
if timer = 0 then dec b54 let timer = 59 : endif
if b54 < 10 then serout C.3,N9600_16,(254,142,"0",254,143,#b54) else
serout C.3,N9600_16,(254,142,#b54) endif
if timer < 10 then serout C.3,N9600_16,(254,145,"0",254,146,#timer) else
serout C.3,N9600_16,(254,145,#timer) endif
dec timer
goto EXPO
EXPO1: ;clears elapsed time, resets and increments counter for frames taken
settimer off
low CAMERA
inc counter : serout C.3,N9600_16,(254,222,#w15)
if counter = frames then goto INIT
let b55 = b7
let b54 = b6
let hrs = 0
let mins = 0
let timer = 0
pause 30
serout C.3,N9600_16,(254,128,"EXP TIME -",254,139,#b55,254,141,":",254,142,#b54,254,144,":",254,145,#b5)
serout C.3,N9600_16,(254,192,"INT TIME -",254,203,#b52,254,205,":",254,206,#b51,254,208,":",254,209,#b12)
settimer t1s_16
let timer = b12
INTER:
if timer = 0 and b51 = 0 and b52 = 0 then goto inter1
if timer = 0 and b51 = 0 then dec b52 let timer = 59 : let b51 = 59 : endif
if b52 < 10 then serout C.3,N9600_16,(254,203,"0",254,204,#b52) else
serout C.3,N9600_16,(254,203,#b52) endif
if timer = 0 then dec b51 let timer = 59 : endif
if b51 < 10 then serout C.3,N9600_16,(254,206,"0",254,207,#b51) else
serout C.3,N9600_16,(254,206,#b51) endif
if timer < 10 then serout C.3,N9600_16,(254,209,"0",254,210,#timer) else
serout C.3,N9600_16,(254,209,#timer) endif
dec timer
goto INTER
INTER1: ;clears counters and loops back to EXPO if counter not = to frame
settimer off
let hrs1 = 0
let mins1 = 0
let timer1 = 0
pause 30
if counter < frames then goto RUNNING
GKP: ;keypad code
Do
Gosub GTKP ' Wait until no key pressed
Loop Until key_value = 0
Do
Gosub GTKP ' Wait until key pressed
Loop Until key_value <> 0
If key_value = 11 Then
key_value = 0
Return
GTKP: ;Keypad scan coding
key_pos = 0
key_value = 0
High ROW1 : gosub ScanCol : low ROW1
High ROW2 : gosub ScanCol : low ROW2
High ROW3 : gosub ScanCol : low ROW3
High ROW4 : gosub ScanCol : low ROW4
Return
ScanCol:
if COL1 = 1 then : key_value = key_pos + 1 : endif
if COL2 = 1 then : key_value = key_pos + 2 : endif
if COL3 = 1 then : key_value = key_pos + 3 : endif
key_pos = key_pos + 3
