This is my first forum experience. I've done some projects using a picaxe before but I've never used the "count" command
and I'm having problems. I'm using a 20M2 to count pulses from a Geiger counter. The program works fine, except the "Count" command isn't putting the count into
the variable w5.
I have C.2 connected to a pulse generater (max output 5vdc.). I know for sure the C.2 input is working, and that the pulse generator is
delivering pulses to C.2 (checked with a scope). I've got the generator set to delivery a square wave at 20 hertz with a 2ms pulse width. I've followed the example in the manual with no results.
When I do a debug, I keep getting the message "debug waiting for data."
Also. The 20M2 is suppose to run at a maximum of 32mhz, yet I've got it running at 64mhz. Is this what is reffered to as over-clocking?
The attached program is a test routine and not the actual Geiger counter program. never the less, I can't even get the "Count" command to work in a simple program.
the variable w5.
