Hello,
I would like to convert a standard thermostat into a wireless one. The main problem I have is that the thermostat is powered with 24 VAC and I don't know how I could interface it with a 08M.
Here is a schematic of how the thermostat should be wired :
Depending on what should be activated (heating, cooling, fan), the thermostat will join pin R to pins W, Y or G.
I would like to keep all simple (ie no LED+LDR, no relay...), and I was thinking in that schematic :
Do you think it could work ? Perhaps instead of standard diodes, I should use Zener diodes (at least for the ones connected to G, W and Y).
What I will do after is detecting which picaxe pin is high and send a serial information through a standard 433 MHz TX. The RX module will then activate the corresponding relay, depending on the message received.
If interested, the installation guide of the thermostat can be found here.
Many thanks for your help.
Christophe
Christophe
