Hi all,
When I see the advanced coding and projects of other members, I have to say I'm a novice to picaxe programming.
Using an 08M2, I'm setting about generating a pulse between C.0 and 0v in order to switch on a 20-second voice module.
A button switch between +5v and C.3, when pressed once should turn on the module, and a 20 second pause is allowed
while the module plays. Following a pause, a tune outputs on C.4 (tune 4, 12, ($14) ).
Then loops back to start. But I want the function to wait until the button is pressed once before continuing to play the module
recording, and the tune. Then back to start again. You get the picture.
Any help welcome.
Any help welcome.
