Always a problem to find raw materials when building projects. I have just used some of this material for a panel to mount infrared illuminators on to go inside an external floodlight box to work as CCTV camera illumination.
I used 3mm stock. It was rigid to use as well as so easy to cut, just score with knife, bend it back and it snaps cleanly. It drills into easily, comes in various sizes and colours. It's not conductive. You can heat it with a low heat to bend it and can maintain it's shape you bend it too.
I'm not on commision, just thought I'd pass it on.
http://www.ebay.co.uk/itm/SINGLE-BULK-1-3-5-10-PK-WHITE-POLY-STYRENE-PLASTIC-HIPS-SHEET-A4-3mm-THICK-/221568729632?
