I'm having a lot of trouble using two picaxe boards connected together to count numbers one to ninety-nine.
im using the following program for picaxe board no. 1
The second board counts of its own accord as if it is not looking for an input.
Any help would be appreciated,
thanks,
Jamie Patel
test:
if pin2 = 1 then flash1
goto test
test2:
if pin2 = 1 then flash2
goto test2
test3:
if pin2 = 1 then flash3
goto test3
test4:
if pin2 = 1 then flash4
goto test4
test5:
if pin2 = 1 then flash5
goto test5
test6:
if pin2 = 1 then flash6
goto test6
test7:
if pin2 = 1 then flash7
goto test7
test8:
if pin2 = 1 then flash8
goto test8
test9:
if pin2 = 1 then flash9
goto test9
test10:
if pin2 = 1 then flash10
goto test10
flash1:
let pins = %00011000
goto test2
flash2:
let pins = %11110011
goto test3
flash3:
let pins = %11111000
goto test4
flash4:
let pins = %10011100
goto test5
flash5:
let pins = %11101100
goto test6
flash6:
let pins = %11101110
goto test7
flash7:
let pins = %00111000
goto test8
flash8:
let pins = %11111111
goto test9
flash9:
let pins = %11111100
goto test10
flash10:
let pins = %01111111
high 0
goto test
... and im using the following program for the second board:
test:
if pin1 = 1 then flash1
goto test
test2:
if pin0 = 1 then flash2
goto test2
test3:
if pin0 = 1 then flash3
goto test3
test4:
if pin0 = 1 then flash4
goto test4
test5:
if pin0 = 1 then flash5
goto test5
test6:
if pin0 = 1 then flash6
goto test6
test7:
if pin0 = 1 then flash7
goto test7
test8:
if pin0 = 1 then flash8
goto test8
test9:
if pin0 = 1 then flash9
goto test9
test10:
if pin0 = 1 then flash10
goto test10
flash1:
goto test2
flash2:
goto test3
flash3:
goto test4
flash4:
goto test5
flash5:
goto test6
flash6:
goto test7
flash7:
goto test8
flash8:
goto test9
flash9:
goto test10
flash10:
goto test
thanks,
Jamie Patel
