Are there any obstacles or protocols that should be used when trying to Connect multiple picaxes to each other via serin/out commands
For instance if I wanted to connect ten pics together via one wire (plus common earth return) and control them from one central circuit, would this be possible if each pic was given its own qualifier eg: ("one") ("two") etc or does the reliability of the serin/out command deteriorate the more pics you try and communicate with?
