jsimpson001
I get a compile error on lhe following line:
if alarmctrl2 = 1 then let statevar1 = statevar1 + 1
it is an empty box, and i can't spot anything wrong with the code.
Any ideas?
Any ideas?
'Alarm UI Controller for PICAXE-28X 4MHz 16x gosub
symbol kpdctrl1 = pin0
symbol kpdctrl2 = pin1
symbol alarmctrl1 = pin2
symbol alarmctrl2 = pin3
symbol statevar1 = w0
symbol statevar2 = b3
symbol errloopvar = b4
symbol lcdbkltcount = b5
init:
serout 7,T2400,(254,14)
pause 30
serout 7,T2400,(254,1)
pause 30
serout 7,T2400,(254,128,"Initializing...")
pause 30
serout 7,T2400,(254,192,"Don't Press Key!")
wait 3
if kpdctrl1 = 1 then errormsg
if alarmctrl1 = 1 then errormsg
if kpdctrl2 = 1 then errormsg
serout 7,T2400,(254,128,"Alarm System")
pause 30
serout 7,T2400,(254,192,"Status: Normal")
goto setstate
setstate:
if kpdctrl1 = 1 then let statevar1 = 1000
if kpdctrl2 = 1 then let statevar1 = statevar1 + 100
if alarmctrl1 = 1 then let statevar1 = statevar1 + 10
goto readstate
readstate:
if statevar1 = 0000 then stateA
if statevar1 = 0100 then stateB
if statevar1 = 1000 then stateC
if statevar1 = 1100 then stateC
if statevar1 = 0010 then stateD
if statevar1 = 0011 then stateE
if statevar1 = 1111 then stateF
if statevar1 = 0000 then stateG
stateA: 'normal
pause 30
goto setstate
stateB: 'key pressed
serout 7,T2400,(254,128,"Please Enter Code")
pause 30
serout 7,T2400,(254,192,"to Set Alarm")
goto setstate
stateC: 'correct code
serout 7,T2400,(254,128,"Code Correct!")
pause 30
serout 7,T2400,(254,192,"Arming in 10s!")
goto setstate
stateD: 'armed
pause 30
serout 7,T2400,(254,192,"Status: Armed")
let lcdbkltcount = lcdbkltcount +1
if lcdbkltcount = 30 then bkltoff
goto setstate
stateE: 'armed, triggered
serout 7,T2400,(254,128,"Alarm!! Enter")
pause 30
serout 7,T2400,(254,192,"Code to Reset!")
goto setstate
stateF: 'armed triggered, code correct
serout 7,T2400,(254,128,"Correct Code:")
pause 30
serout 7,T2400,(254,192,"Resetting...")
goto setstate
stateG: 'normal
pause 30
goto setstate
bkltoff:
'bkltpins must go low here.
goto setstate
sendback:
'if then loops here.
goto errormsg
errormsg:
serout 7,T2400,(254,128,"Fatal Error!")
serout 7,T2400,(254,192,"Please Reset Sys")
let errloopvar = errloopvar + 1
if errloopvar = 30 then turnalloff
wait 1
goto errormsg
turnalloff:
serout 7,T2400,(254,10)
let pins = %0000000 'perhaps a fault light here*
end
