Solar Mike
Here is a basic design for a PWM type PV solar charge controller, using a Picaxe 08M2. Ideal for smaller 30W panels charging a 10AH or so lead acid battery.
I have a number of projects coming up that require small panels hooked up to various size 12 volt gel or Lifepo4 batteries, in stand alone field operations powering pumps, control valves etc. After playing with various designs for small MPPT controllers, MPPT is really over-kill for small setups, so am switching to simple PWM only.,
Sorry about smd components used here, everything I build now uses smd components.
Having many small dual logic level mosfets (30v @80amps 5.2mR) left over from a Lifepo4 BMS project, decided to use them in this design; the PV charger part is 2 back to back devices (single package) driven by a current to voltage isolated mosfet driver, these drivers originally designed for use in SSR's have on\off times approx 1mSec so the PWM frequency must be quite low, quite ok for a battery charger.
The high side load switch has two in parallel to bring the series resistance down, this switch gets turned off should the battery volts get too low.
A novel part of this circuit is the load switch is driven from the C.3 input only pin, by programmably setting the C.3 pull-up on, the output voltage divider feeding the schmitt trigger inverter gate is set high; and low when the pull-up is disabled.
Schematic below:
Cheers
Mike
Schematic below:
Cheers
Mike
