Markbishop16
Picaxe 18m2+, Picaxe 18 project board, not high power
I have a simple project that at maximum current may draw 600 ma which is 100 ma more than the project board output.
Max load will operate for seven seconds then it will reduce using pwm, the lower constant current will be nearer 380 ma this will be on for 3 hours before turning off.
Can I common B.3 and B.6 to share the load.
Thanks.
Thanks.
