Tumbledown
The problem is that the port assigned to the Axe027 cable seems to move about after the cable is disconnected/reconnected.
I am running win7 64bit, axe027 cable and have good communication with my test board. I can run and download programs.
I have updated to the latest drivers, Logicator and Picaxe Programming Editor and always attach the cable to the same USB port.
I assigned port 2 in the system device driver for the axe027 and port 2 in the Logicator and things are OK at first.
The next time I connect the cable and try to run, I get the port not available but another port shows available.
Then I try the Picaxe Programming Editor and it works on port 2.
I try the Logicator and the port is unavailable.
I can't use port 2 until I go back to the control panel and change to the new port there.
Now when I look at the picaxe type/ports settings, it show 2 unavailable axe027 ports and a third one available.
I have fixed this one time by uninstalling the Picaxe Programming Editor and reinstalling it.
Is there a problem running the Logicator sometimes and then the Picaxe Programming Editor other times?
How do you make the USB connect to the same serial port everytime?
