Com Port not found when programming subsequent chips
#1
Edit: Got the title wrong -- it's finding the COM port, but not finding the chip.
I've created a batch file to program three slots of a 28X2 in one operation. It is working very well, taking about 45 seconds to completely program a chip which is much faster than doing it manually.
My problem is that when I insert the next chip to repeat the process, I get
Error: Hardware not found on COM6!
I can correct this by momentarily unplugging and replugging the USB-to-serial cable (I'm using the AXE 027), but I'd rather fix the batch file if I am doing something wrong.
I am not using any switches in the command, only the three following lines for the three slots:
picaxe28x2 -cCOM6 v47slot0.bas
picaxe28x2 -cCOM6 v47slot1.bas
picaxe28x2 -cCOM6 v47slot2.bas
Any thoughts about this?
#2
I can't think of any cause for the behaviour you are seeing. If there were issues with the serial port between programming one PICAXE and the next I would have expected there to be similar problems between programming slots of the same PICAXE.
#3
Thank you for the response, hippy, I'll keep experimenting. It may be that my older computer's USB firmware isn't as good as it might be.
I must say that the compiler with batch process is slick and fast and beats heck out of using PE6 when programming multiple slots and/or chips! If I can get it working really well I want to try having it program three chips on three COM ports in one operation.
