Colour Change Shower Head - Powered by Water Pressure
DDJ2011
While surfing ebay for cheap kit I came across these colour changing shower heads - has anyone seen these or made one?
I'm curious how the water pressure powers the circuit?
Item description includes:
No battery needed, it is powered by the pressure of water,Very environmental.
Can be used more then 6000 hours.
Below 25 C,Lights Green.
From 26C -35C,Lights Blue.
From 36C -45C,Lights Red.
Above 46C -Red Strobe(Alarm).
Why not be original and design a plastic duck for the bath that changes colour and propels itself along using a Microblower.
(I wonder if they'll do a version that can pump fluid).
There you go; 2 copyrightable ideas in a single post :)
Mind you, with Ec's search-fet he'll probably find this has been done already.
manuka
Colour/color changing shower heads are certainly innovative (& may eventually become a safety standard), but experiences with cheap ones indicate leaks,reduced flow pressure,noise & premature failure of the microturbine may occur.
As water pressure is essentially "free" they're really nothing new (refer past US patents),& such indicating shower units are merely just piggy-backing on coloured LED energy improvements.
Of course it's tempting to hack one for pressurised PICAXE powering,although (compared with solar power) water wasting may become an issue...
"...experiences with cheap ones indicate leaks,reduced ...."
- sounds like Stan has been buying cheap CH goods again ;)
I wish my water was free! I think it's over 80p per cu metre , so a fully staffed Nuclear Power station would be a cheaper way of lighting some LEDs :)
I think someone is spending too long in the bath if they need a rubber duck, whats next a teddy bear for bed time???
- Uh oh , that'll get the Googlemeister going again :)
One day they'll invent a solar+wind powered clothes drying device.
