M malti New Member Nov 24, 2009 #1 Has anyone ever programmed a Picaxe, such as the 18x to act as an LC meter or separate coil and capacitor meters ?
E eclectic Moderator Nov 24, 2009 #2 See this thread as a start: http://www.picaxeforum.co.uk/showthread.php?t=11991&highlight=capacitance+meter Then try a further Forum search. e
S Svejk Senior Member Nov 25, 2009 #3 I did. [lenghtened at request] Attachments LC meter 001.jpg 60.9 KB Views: 101 LC meter 003.jpg 64.6 KB Views: 71 Last edited: Nov 25, 2009
W westaust55 Moderator Nov 25, 2009 #4 Silicon Chip magazine had an article on a PIC (not PICAXE) based digital high accuracy LC meter in May 2008. http://www.siliconchip.com.au/cms/A_110500/article.html If you click on the first image (the front-end circuit) you will access a slide show which gives more photos and the full schematic. Obviously you will be up for working out your own PICAXE BASIC program code.
S Svejk Senior Member Nov 25, 2009 #5 I've dug up the schematic, DipTrace file, just change the extension to *.dch An oldish design, it may have errors, it pays to double check. I would do things a bit diferently now that Picaxe X2 is on the market. Attachments lc meter.txt 160.4 KB Views: 79
