Code won't run in VSM but does in programming editor
deneve
Ok I'm new to VSM and am having no end of trouble with it. It seems to be performing really oddly. I must be doing something wrong so I tried a very simple circuit which still does'nt function properly. The code works fine in the picaxe programming editor. But fails somehow in the VSM. It starts to run in the VSM when I use pause, but when I try to debug it, stepping through just closes the code windw of the program so I cannot see what's going on. Needless to say what you see is not what should happen. Output 0 and output 1 should alternate on and off for one second but all that happens is output 0 stays on.
I've puzzled over this and thing I must be doing something really stupid.
Can anyone give me a hint as to what is wrong? Help!!!!
Many thanks for any help offered.
deneve
Oooops Now I've figured out the mistake - it was very stupid! Reset button not properly tied up to positive.
Duhh!
