; b0 is switch 1
;b1 is i2c sda
;b2 is switch ;2
;b3 is switch 3
;b4 is i2c scl
;b5 is motor reverse relay
;b6 led display
;b7 infra red receiver
;c1 is 240 volt heat relay
;c0 is 12v volt power relay
;c7 infrared leds
;c6 circulation fan
symbol seconds = b0
symbol mins =b1
symbol hour = b2
symbol day = b3
symbol date = b4
symbol month = b5
symbol year = b6
symbol control = b7
;set ds1307 slave address
i2cslave %11010000, i2cslow_8, i2cbyte
;initialise clock
let day =$01
let year = $13
let month = $02
let date = $17
let hour = $11
let mins = $48
let seconds = $00
let control = %00010000
writei2c 0, (seconds,mins,hour,day,date,month,year,control)
;read clock time
readi2c 0, (seconds,mins,hour,day,date,month,year)
;report time
start:
serout b.6,n2400, (254,1)
pause 30
readtemp C.2,b27 ; read value into b27
serout b.6,n2400,(254,128,#b27,"C")
if b27<20 then heat ; turn on heat source
if b27 >23 then heatoff 'turn off heat
heat:
high c.1
high c.6
gosub main1
heatoff:
low c.1
low c.6
gosub main1
main1:
hi2cin 0, (b0,b1,b2,b3,b4,b5,b6)
pause 100
bcdtoascii b0,b19,b20 'Secs Convert to ASCII
bcdtoascii b1,b8,b9 'Mins
bcdtoascii b2,b10,b11 'Hours
bcdtoascii b3,b21,b22 'DayOfWeek;
bcdtoascii b4,b12,b13 'Date
bcdtoascii b5,b14,b15 'Month
bcdtoascii b6,b16,b17 'Year
if b8 ="0" and b9 = "1" and b19="1" then gosub turneggs
if b8 = "0" and b9 ="2" and b19="1"then gosub turneggsback
if b8 = "0" and b9 = "3"and b19="1"then gosub turneggs
if b8 ="0" and b9 ="4"and b19="1" then gosub turneggsback
serout b.6,n2400,(254,136)
serout b.6,n2400,(b10,b11, ":",b8,b9,":",b19,b20)
serout b.6,n2400,(254,200)
serout b.6,n2400,(b12,b13,"/",b14,b15,"/",b16,b17,254,192)
If b22="1" then serout b.6,n2400,(254,192,"Sun ")
elseif b22="2" then serout b.6,n2400,("Mon ")
elseif b22="3" then serout b.6,n2400,("Tue ")
elseif b22="4" then serout b.6,n2400,("Wed ")
elseif b22="5" then serout b.6,n2400,("Thur")
elseif b22="6" then serout b.6,n2400,("Fri ")
elseif b22="7" then serout b.6,n2400,("Sat ")
endIf
turneggs:
high c.0 ;starts the turn motor
pause 500 ; allows the Infrared sensor to get away from the IR led
high c.7
; turns on the IR leds
eggsturning:
if pinb.7 = 1 then turnoff ;IR sensor
if pinb.7 = 0 then eggsturning
turnoff:
low c.0
low c.7
pause 8000
turneggsback:
high b.5
pause 30
high c.0
pause 500
high c.7
goto eggsturningback
eggsturningback:
if pinb.7 = 1 then turnoff1
if pinb.7 = 0 then eggsturningback
turnoff1:
low c.0
low b.5
pause 8000
