B bluejets Senior Member Nov 5, 2012 #1 In the example code I found, does the W1 register become over written on each loop..?? Code: main: pulsin C.3,1,w1 ; record the length of a pulse on C.3 into w1 debug ; report the result goto main ; and repeat
M MartinM57 Moderator Nov 5, 2012 #2 Yes, but it may be overwritten with the same value of course. It would be really odd if it didn't Why do you ask?
G Goeytex Senior Member Nov 5, 2012 #3 W1 will indeed be overwritten on each loop. To see it work, have a second Picaxe send incrementing value pulses to the first. Code: [FONT=Courier New]Do for w0 = 1000 to 10000 step 100 pulsout c.1,w0 pause 200 next loop [/FONT] The pulsin / pulsout values should match assuming both Picaxe's are operating at the same frequency.
B bluejets Senior Member Nov 5, 2012 #4 Ok...thanks.....wasn't sure if it needed to be reset. I couldn't find anything about the need to reset but thought I'd ask just in case. Thanks again.
